So, mußte mal was anderes tun. Nun wieder dran, mit neuem Mut.
Hier der Log, folgendes gemacht!
******* drüber
eraser drüber und
2.72 mit b_d drüber.
Das ist der Log.
Kannste damit was anfangen???
Wird der CI-Max doch noch angezeigt???
SAA1064 Display
2MB Hardware .. idx= 0
CPU: TMX320AV7111, Flash 2MB
galaxis zapping team
Download mode !!!!
File Check-Sum 9299
DRAM Check-Sum 9299 OK !
Program run area at 0x2c100000 to 0x2c1b7968 ... ok !
2MB Run area
program ok !
End Download !!!ÿ
SAA1064 Display
Jump only first(0) Ver 17 check 9299 addr 2c100000 !
SAA1064 Display
EASY project Apr 23 2004 at 17:11:40
ERROR: EEP struct 7 (LNB_on_off): 255,
ERROR: EEP struct 0 (SatNr): 255,
ERROR: AV struct(LANG) : 65535
ERROR: osdtyp : 0x0
ERROR: time zone : -107
ERROR: modem_block !
ERROR: fav_block Name[0] >ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
ERROR: fav_block Name[1] >ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ<
ERROR: fav_block Name[2] >ÿÿÿÿÿÿÿÿÿÿÿÿ<
ERROR: down_block trp=65535
Load SAT defaults ..
---- End of system check ----
DRAM free: 0x2e043730 space 0x1ce30
SDRAM free: 0xcc2e1cc8 space 0xe1cc8
USR St Base: 0x2e006f08 Size: 0x80
UDF St Base: 0x2e006f88 Size: 0x80
ABO St Base: 0x2e0070
IRQ St Base: 0x2e007088 Size: 0x80
Priv Base: 0x2e026880 Size: 0x80
Priv Value: 0x00000000
Heap Base: 0x2e026900 Size: 0x1d14ff
Flash1: 0 - AMD 29LV160B , 5 waits
EEPROM: 24C16 (2Kx8)
Display: SAA1064 Display
Frontend: SAT Alps BSRU6
AudioV Mux: CXA2161 2 scart
Dolby AC3: Dolby AC3 CS8405a
RF Modul: ---
Modem: ---
Common IF: CIMaX 2 Slot - gx V1.00 at Nov 04 2004 / 10:22:40
Beta IF: ---
MacroVision: MacroVision on
Firmware vs: 95/96/xx-294 Y
Update ver.: not available, ASTRA1_SSU ID=96
=== DEVICE on ====
SAA1064 Display
2MB Hardware .. idx= 3
Download mode !!!!
File Check-
DRAM Check-Sum 33 OK !
Program run area at 0x2c1ff000 to 0x2c1ff980 ... ok !
program ok !
End Download !!!ÿ
SAA1064 Display
no Software found !!!!
File Check-Sum 739f
DRAM Check-Sum 739f OK !
Program run area at 0x2c100000 to 0x2c10a178 ... ok !
2MB Run area
program ok !
End Download !!!ÿ
SAA1064 Display
Jump only first(0) Ver 0 check 739f addr 2c100000 !
SAA1064 Display
galaxis FLASH ERASER ver 1.3 Sep 07 2001 at 22:01:32
1.Flash Manufacturer: SST SST39LF160, MfId = bf, DevId = 2782
2.Flash not present
Begin to ERASE 1.flash at 0x2c010000
Begin to ERASE 1.flash at 0x2c110000
Erasing successful !!!!!!
EEPROM 24C16 exist
delete EEPROM ........
EEPROM finishÿ
SAA1064 Display
File Check-Sum 39ff
DRAM Check-Sum 39ff OK !
Program run area at 0x2c100000 to 0x2c1c61e0 ... ok !
2MB Run area
program ok !
End Download !!!ÿ
SAA1064 Display
Jump only first(0) Ver 0 check 39ff addr 2c100000 !
SAA1064 Display
ERROR: EEP struct 0 (LNB_on_off): 255,
ERROR: osdtyp : 0xffffffff
ERROR: HW_ident check sat world
ERROR: fav_block TV[0] = -1 > 65535
---- End of system
USR St Base: 0x2e006ae4 Size: 0x80
UDF St Base: 0x2e006b64 Size: 0x80
ABO St Base: 0x2e006be4 Size: 0x80
IRQ St Base: 0x2e006c64 Size: 0x80
Priv Base: 0x2e0207c4 Size: 0x80
Heap Base: 0x2e020844 Size: 0x1d35bb
RF Modul: ---
Modem: ---
Common IF: CIMaX 2 Slot - V1.63 at Apr 24 2002 / 16:55:39
Upd sw ver.: not available, SSU 96/96
=== DEVICE on ====
Start TestTask
Int. Test SW:>
