Aktuelle Zeit: So 6. Sep 2026, 04:05
 Betreff des Beitrags: Firmware Update v3.0
BeitragVerfasst: Do 5. Feb 2004, 19:54
Bei GoldTop gibt es ein Firmware Update für EasyPlus (früher Matrix SX lite).
Die Firmware läuft auf Easy CI und McZap SCI, aber nicht auf Matrix S und McZap S (Samsung Tuner).
Viel Spaß.
oli
v3.0 (03/02/04)
- patched EIT present/following acquisition to accomodate Sky Italia uncorrect EIT transmission
- skipped otv tracks
v2.9a (13/10/2003):
- added HotBird + Sky channel list
- fixed language selection on some services
v2.9 (30/09/2003):
- fixed behaviour on diseqc systems
- C-band LNBs support
- non DVB-compliant transponders supported (not unique SID/ONID/TSID tripplets)
- other changes and improvements
v2.8a (November, 14th 2002):
- CI navigation menu bug fixed (present only in v2.8)
- Timers handling in stand-by mode reworked
- Power and quality signal level normalized
v2.8 (November, 7th 2002):
- user-customizable backgrounds
- "PC link" mode to connect STB with a PC via serial port
v2.6 (August, 6th 2002):
- channels list handling functions reworked
- channels and favourites list updated
v2.5 (August, 1st 2002):
- 8 favourite lists for TV and 8 favourite lists for radio
- channels can be renamed, also through remote numeric keypad (mobile phones style)
- 8 timers with "rmeinder" and programmable repetition
- volume level preinitialized to 7 at first boot
- improved event acquisition engine
- updated default channel list (now only RAI/Mediaset/Tele+/Stream bouquets)
- installation procedure more stable
v2.1 (July, 2nd 2002):
- 8 event timers with on-screen "reminder" capability (notification advance
can be configured)
- way of saving favourite lists is changed: changes in main channel list don't
affect favourite lists
- multiple favourite lists with possibility to give a name to each list.
Cycle through default and favourites by means of the RED button
- Free-To-Air filtering of channel list (default/favourite)
- alphabetical direct-to-letter navigation in channel list
(default/favourite) by means of numeric keys. Alphabetical and FTA sorts can
be combined.
- channel lock (in addition to dynamic parental control)
- channel search/edit operations are now entirely performed in DRAM, instead
of FLASH, this allows faster access to lists and the possibility to undo the
results of changes. Saving question at the exit od setup controls all the
changes
- selective channel search on TV/Radio/Interactive channels
- automatic adjustment of system time on those transponders transmitting
wrong GMT reference (e.g. Mediaset and Stream on Hotbird 13E). This allows
to keep validity of event data acquired on transponders with correct GMT
time
- faster alphabetical reordering of channel list (default/favourite)
- faster switch between setup and banner applications
- added Spanish as 4th language
- fixed AGC control
- last volume level resumed after power on
- samsung tuner driver included (Matrix only)
- fixed bug on deletion of last channel only from a favourite list
- normalized power and quality signals
- power and quality signals added on DVB infos panel in place of continuity errors
- added radio background
- changed graphics for backgrounds and OSD colors (new remote picture added in
"Italy_lite" help)
v1.6 (April, 9th 2002):
- added a popup box showing DVB infos (keep '0' pressed to activate)
- new common interface library
v1.5 (March, 20th 2002):
- added key to stop channel search
- improved channel list handling in setup application
- fixed bug on Navigator exit (screen blank)
v1.4 (March, 15th 2002):
- added AGC control in setup
- added channel change mode setting (blank or freeze) in setup
- (Lite) intergated automatic update of bootloader to version 2.5
- "exit" function in PIN dialogue box for parental control
v1.3 (March, 11th 2002 - not released):
- 16:9 signalling on SCART pin 8 and with WSS
- letterbox option (4:3 mode)
- CI status messages in setup
- fixed bug with Sport Stream channel (interactive mode)
- faster channel search
- setting of satellite sw dawnload parameters from setup
- fixed bug with NIT acquisition on Stream
- improved navigation through CI menus in setup
v1.2 (February, 8th 2002):
- new flash memory driver
- CI modules init/ready screen messages
- new subtitles graphics
v1.1 (February, 6th 2002 - not released):
- fixed bug with "Save" functions after channel search
v1.0 (January, 30th 2002):
- initial release
Mitglieder in diesem Forum: 0 Mitglieder und 30 Gäste
