Aktuelle Zeit: Mi 4. Jun 2025, 19:04
 Betreff des Beitrags: Info zu seca!
BeitragVerfasst: Sa 17. Jun 2000, 15:38
Hab nach langem suchen was über das heutige seca-problem gefunden. Kann das jemand überprüfen?--
Your seca card will work tomorrow
Saturday, 17-Jun-2000 09:44:57
HI,
it's normal that you can't watch seca channels today with a basic piccard.
The reason is simple.
Today the date (17 june 2000) is coded 14 D1 in Little endian.
Piccard use D1 as separator for instruction 3C.
In others simple words, your card will work at midnight.
You can simply modify your source by adding an offset of 11 bytes in front of the instruction 3C, then you will avoid the date problem.
Tomorrow you won't have any problem, your card will work fine...
Galager
BeitragVerfasst: Sa 17. Jun 2000, 15:46
Schau mal ein Topic vorher Bild
