Gerne doch hier kommt prompt: Ich hoffe Du kannst Englisch, ansonsten hilft Babbelfish sicher gerne weiter
Digiality IR-CI 103
Short description Satellite receiver with embedded Irdeto and 2 common interface slots.
Sales description Digital satellite receiver (QPSK) Embedded Irdeto One smart card reader Two common interface modules S-VHS out The Digiality IR-CI it one of the first receivers in a new product range. The receiver has an easy to use menu system. The receiver can store up to 2000 channels and supports subtitles.
Features Capable of descrambling encrypted programs by Irdeto using build-in Irdeto Descrambler 2 Common interface slots Fully MPEG2, DVB compliant High quality Digital Video & Audio output Various channel editing functions (favorite, moving, locking, renaming, deleting and sorting) Automatic search for newly added transponders Stores up to 2000 channels Volume level saving function for each channel Fully support EPG Fully support Teletext & Subtitle by OSD SCPS/MCPC receivable from C/KU Band
Technical data Tuner & Channel Input Connector F-type, IEC 169-24, Female LNB Supply 13-18V 22 KHz Tone Frequency: 22 DiSEqC Control Version 1.0/1.2 compatible 0/12V DC Output Current: Max. 100 mA Demodulation QPSK Input Symbol Rate 2 - 45 Ms/s FEC Decoder Code Rate 1/2, 2/3, 3/4, 5/6 & 7/8 MPEG Transport Stream A/V Decoding Profile Level MPEG-2 MP@ML Aspect Ratio 4:3, 16:9 Video Resolution 720 x 576 Audio Decoding MPEG Layer I & II Audio Mode Single channel / Dual channel Joint Stereo / Stereo Conditional Access Interface Embedded 1 Smart Card Reader PCMCIA 2 slot Common Interface A/V Data In/Out TV Scart Video Output (CVBS, RGB), VCR Scart Video Output (CVBS) Video Input (CVBS) Video RCA/Cinch, Video Output (CVBS) Audio R/L RCA/Cinch Volume and Mute Control RS-232C Transfer rate 115 Kbps 9 pin D-sub Type RF-Modulator RF-Connector 75Ω, IEC 169-2, Male / Female Frequency 470 to 860 MHz Output Channel CH 21 - 69 for the Remodulator TV Standard PAL B/G/I/D/K selectable by Menu Power Supply Input Voltage 90 to 250 VAC, 50 Hz / 60 Hz Memory CPU STi5500 Flash Memory / EEPROM 1 Mbyte Graphic DRAM 4 Mbyte
gruss
_________________ gruss -----------------------------
Es lebe das freie Ostfriesland Eala frya Fresena
