Aktuelle Zeit: Mo 19. Mai 2025, 02:46
 Betreff des Beitrags: 140x135x30mm + Erotik Doppelpack
BeitragVerfasst: Do 1. Mai 2003, 09:25
MAXIMUM FTA 100
Free to Air
Dimension 140x135x30mm
Adpterkabel Scart beiliegend.
Application system Ressource
Main Processor STi5518
SDRAM Memory 8 Mbyte
Flash Memory 2 Mbyte
EEPROM 256 Kbyte
Tuner / Demodulator
Input frequency
950-2150 MHz
Signal Level -65 to -25 dBm
LNB supply 13/18V, Max 400mA
Demodulation Method QPSK & FEC
Symbol Rate 2 - 45 Msps
Band Switch Control 22 KHz
DiSEqC Switch 1.2 Compliant (Stab - USALS)
Loop through Supported
Video Decoder
Profile Level MPEG-2 MP@ML
Video Output AUTO (PAL/NTSC)
Stream Data Rates up to 15 Mbits/s
Resolution PAL (720x576@25Hz)
NTSC (720x576@30Hz)
Video format 4:3, 16/9
Letterbox mode supported
Audio Decoder
MPEG 1 layer I and II Decoding
Sampling frequency 32, 44.1, 48 KHz
Sampling Rate 256 fs, 384 fs
Audio DAC Resolution 16 / 18 bit
Rear Panel
1 LNB Input F-Type
1 LNB Output Loop Through F-Type
Video Output 15 Pin D-Sub
Power Input 8 Pin DIN
General Information
Power type External adaptor
Power consumption Max. 30W
Input Voltage AC 100-240V (47-63Hz)
Software Download RS232 Software Download
Weight 280g (excl. power supply)
Accessories (included)
Scart connector
Power supply and power cord
Remote control
129€
Große Sex View Bundle Angebote.
Jetzt im Erotik Doppelpack !!
Besteht aus:
Icecrypt CI Modul ohne Laufzeitbegrenzung
(incl. Free X-TV) +
Viacess Sex View Karte
Laufzeit 1 Jahr
325€
http://www.seidel-shop.de
http://www.seidel-shop.com
