Some bugs have now been fixed 27/2/01
The DIGIQUEST P2000 can be updated with the 2.7 version.
Just in case you need it here are the instructions to download the version
Hot Bird Fréquence : 12 673 Pol : VERTICAL SR: 27500
1 - Switch off the Digiquest by the button on the back
2 - Switch on the Digi using the button on the back and pushing the UP and Down front buttons on the same time. Wait 5 secondes and release the front buttons.
3 - That's it ! After few minutes the version is updated to 2.7
What will be noticed:
1 - Up to 3000 channels (Hot Bird + Astra = 2200 channels after reload)
2 - Multi UHF PAL choices (I,G,etc...). You can now watch the sat on every TV using UHF
3 - Gain recept : + 5db
4 - Several message fixed (Empty favorite list, etc...)
and probably much more
Digimon
