Aktuelle Zeit: So 20. Sep 2026, 05:38
 Betreff des Beitrags: Neue Topfield TF-4000 PVR Firmware
BeitragVerfasst: Fr 4. Okt 2002, 15:43
1. IRD status of Sep 30 2002 version
(1) system id: 206
(2) loader version: A3.06
(3) device version: v4.3.54
(4) application version: TF-JPC 4.57.51
(5) last update: Sep 30 2002
2. Improvements of this version
(1) The fonts of 'W', 'X', 'O' and 'D' in software teletext are changed to clearer ones.
(2) The font of a white space in software teletext is fixed.
In the previous version, it showed as 'ae'.
(3) There were some problems in DiSEqC 1.2 when you delete and add the satellites. It is fixed.
(4) The USALS (DiSEqC 1.3) is supported.
(5) A bookmark is saved at the end of time-shift playback when you are watching the recording service
with time-shift mode. This is from that the end of recording stops the time-shift playback.
(6) If the system boots by the delayed recording, the channel shall be the recorded channel.
(7) The contents of extened EPG in EPG mode were not correct sometimes. It is fixed.
(8) The following problem is fixed.
"If you program a repeating timer, for the validation if that time is already blocked by another timer,
only the first occurence of the repeating timer is checked."
(9) If you locked the recorded file of CONAX, the system could not decramble it with the embedded CAS.
(Only in TF4000PVR COCI) It is fixed.
3. To be improved at the next version.
(1) TF4000PVR does not support the subtitle completely. You can check it in some Canal+ services.
It will be fixed at the next version.
(2) Some other bugs in subtitle will be fixed.
Download:
<a href="http://www.topfield.co.kr" target="_blank">http://www.topfield.co.kr</a>
Gruss,
Bernd Friedewald
<a href="http://www.bfm-satshop.de/" target="_blank">http://www.bfm-satshop.de/</a>
BeitragVerfasst: Mo 7. Okt 2002, 10:43
Da es noch einen groben Bug in der Aufnahmeprogrammierung gibt, empfielt es sich, auf das angekündigte Update in den nächsten Tagen zu warten.
Akrapovic
