Aktuelle Zeit: So 18. Mai 2025, 07:51
 Betreff des Beitrags: Neue beta Software (216) für Echostar DVR 7000 und 5000
BeitragVerfasst: Fr 22. Mär 2002, 11:45
Leider alles in englischer Sprache.
EchoNAV 2.0 Beta release for DVR-5000 HDD and DVR-7000 HDD
B E T A S O F T WA R E R E L E A S E !
We thank you for downloading our beta software from our web site.
This software release adds new features to the EchoNAV user interface and improves the functionality of the previous version.
With the official release we will also release a service letter which details all the features and improvements we have made.
Highlights for this beta release:
- New languages added
- Group and sort behaviour is revised to remember the setting
- Channel information (TP, SR and PID) available under the i-key.
- Manual local oscillator entry introduced
- Improved EPG behaviour
- Improved IF-scan behaviour
- Improved signal quality and strength indicator
- Improved SAT-key behaviour
- Save changes pop-up introduced
- Faster move functionality.
- Edit functions separated.
- Skip forward and skip backward key on the RCU activated for DVR mode to skip to indexes
- Indexes made visible in the InfoBanner
- Last played index added
- 1x Fast forward and 1x rewind added
DVR-7000 HDD only
WARNING !
Before you install the new beta-software, you have to erase all data from the hard disk.
This is required for the installation of the photo album onto you receiver.
Failing to do so will lock your receiver for further use.
Recommended procedure:
Back-up all data that you want to keep onto VCR tape,
Download the software into the receiver and erase all data and the memory
(full Factory Reset)
- Photo album added
- East-West limit menu added
- Improved positioner behaviour
- Skip forward and skip backward key on the RCU activated for MP3 mode
More detailed information about new features:
- New languages added:
Spanish, Italian, Polish, Greek, Swedish and Serbian-Croatian.
The Grouping and Sorting settings in the channel list are remembered in EchoNAV2.0.
This means that any grouping or sorting applied in the channel list will remain active until
changed. To aid the user in determining whether he has a Grouping or Sorting option
selected we have placed an icon on the InfoBanner to indicate this.
This icon will change depending on whether you have selected the All List,
Current Satellite list, a favorite list or if Grouping/Sorting is selected.
The user therefore can see in a glance what the status is.
Please be aware that you can get empty lists if the group/sort setting gives no results.
For certain customers it is important to be able to call up additional channel information
when zapping. This is now possible in EchoNAV2.0 by pressing the ‘I’ key three times
(once to show the InfoBanner, a second time to show the extended EPG information, and the third
time to show the additional channel information
In EchoNAV2.0 you can enter a LO frequency directly when creating a User LNB.
- EPG
In EchoNAV2.0 the start and stop time is shown in the extended EPG information screen
(press ‘i’ key twice while watching a channel). This is especially helpful when scrolling
through multiple day scheduled EPG information.
In EchoNAV2.0 after making changes in the channel list (move, lock, delete, hide, volume, rename, etc.) you are prompted to confirm these changes. In some cases if users would “play” with the software and unknowingly for instance delete a channel, it was previously not possible to undo these changes.
In EchoNAV2.0 you are prompted to confirm these changes before they become permanent.
- Faster “Move” Functionality in Channel Lists
- Direct channel number entry
During a Move you can enter the channel number where the selected channel should be placed.
- Recall after Move
After dropping a channel in its new place you can press the Recall key to jump back to the spot in the list where you came from. This allows you to quickly jump back and forth between for instance the end of the list and the beginning of the list when moving channels.
- Set East/West Limit Menu
We have included a new menu under the Installation menu for setting East/West limits.
This allows the user to move the limits after the receiver has been set up.
In EchoNAV2.0 we have separated the various editing functions.
In the previous software version when you select Move for instance, you would also be shown the lock and delete options at the same time.
In EchoNAV2.0 you only see the selected Edit function (only Move for instance).
We feel this is less daunting to the user and it also enhances speed in certain instances.
- Photo album added:
With the mode selection (red key) you can access the photo-album.
You can only download the photo's onto the hard disk from a PC with use of the dedicated
USB Loader which is part of this beta-software package. (Supported extensions are BMP and JPG)
You can select a photo from the list with the OK key, skip forward key >| gives the next photo,
skip backward |< gives the previous photo and play shows them automatically with a certain interval.
With the InfoBanner in view, you can access the special menu with the MENU key (same as within the DVR mode).
- Indexes:
In the DVR-mode you can set indexes in a DVR-recording. These indexes are now shown in the progress bar which is available in the InfoBanner.
When you set more then one index per event you can move quickly to teh next index with the skip forward >| or skip backward |< key on the remote control unit.
When you leave a running DVR recording, the software adds automatically an index which is called 'last played', so you can easily continue to view a next time.
Keep in mind that this index is erased automatically when you leave another recording.
When you have any comments, please send your comments to mailto:echonav.beta@echostar.com
Please be so kind to inform us which receiver, dish installation and software version you have used.
Rokie
BeitragVerfasst: Mi 10. Apr 2002, 15:45
Wie Gut laufen eigentlich die Echostar Festplattenreceiver ?
Ich hab selbst mit beiden Hyundais nur schlechte erfahrungen gemacht.
inzwischen hab ich sogar wieder ein ganz normalen Sat Receiver. Ich wollte die Geräte erstmal bischen Zeit zum reifen geben.
Topfield wird andauert fehlerfreier aber läuft auch nicht 100% obwohl man wohl schon damit Leben kann soweit wie ich das mitbekommen, ausserdem gibts da nun auch Modelle in Silber.
Da es in nächster Zukunft wohl keine neuerern Geräte gibt, Humax wartet wohl drauf bis ihr Gerät fehlerfrei läuft, was sicher nie der Fall sein wird, wie man bei der Konkurrenz sieht <img border="0" title="" alt="[Zwinkern]" src="wink.gif" />
Also was Kaufen, die einzig Alternative mit "Namen" ist für mich Echostar.
Hier hab ich irgendwie noch nicht so richtig viel Reports gelesen, und noch garnix schlechtes, was eigentlich nur heissen kann das die User vor der Glotze sitzen anstatt sich im Internet über Fehler der Geräte zu Unterhalten wie die Topfield User ?!
Ist das so, wer hat einen Echostar und kann mal was sagen, Preislich sind die Echostar 5000 und Topfield 4000 ja Identisch.
adios
Kily
BeitragVerfasst: Do 11. Apr 2002, 15:56
Ich bin sehr zufrieden mit meinem DVR7000CHD, anfangs (mit der ersten Software) waren noch ein paar kleine Bugs enthalten, beim schnellen vorlauf eines auf der Festplatte aufgezeichneten Films konnte es passieren, das der Ton plötzlich
nicht mehr Lippensynchron war.
Auch war der "Sat" Knopf auf der Fernbedienung noch nicht belegt, sodas man, wenn man auf einen anderen Satelliten wechseln wollte erst ins Menü musste.
Mit den neueren Softwareversionen sind diese Fehler aber beseitigt worden.
Zusätzlich ist noch ein Fotoalbum hinzugekommen, man kann mehrere Tausend Bilder von zb. einer Digitalen Fotokamera auf die Festplatte kopieren (über USB) und diese dann wie in einer Diashow oder auch einzeln abspielen.
Ferner kann man auch mp3 Musikdateien über USB einladen und abspielen.
Diese beiden Funktionen habe ich aber noch nicht ausprobiert, da ich die Software mit dem Fotoalbum erst ein paar Tage installiert habe und ich (noch) keine Digitalkamera habe.
Mit der Fernbedienung kann man noch drei zusätzliche Geräte steuern, TV;VCR;CD-Player oder andere, die Multifunktiostasten sind auf viele
andere Geräte Programmierbar.
Aufhänger habe ich noch keine gehabt, Bildqualität ist sehr gut, was die
umschaltgeschwindigkeit angeht, habe ich noch keinen schnelleren gesehen, das Bild
ist praktisch sofort da, wie bei analogem TV.
Der DVR 7000 kann auch analoge Tv Sender wiedergeben und eine Drehanlage ansteuern,
der DVR 5000 kann nur Digital TV.
Das einzige, was mich ein wenig stört ist die Tatsache, das der Receiver alle Programme der verschiedenen Satelliten der Reihe nach durchnummeriert, zb Astra 001 bis ca 600 dann Eutel 600-700, Hotbird 700-1300 usw.
Das war ich bisher zb vom AD3000IP anders gewohnt, da wurde bei jedem anderen Satelliten
wieder bei 1 begonnen.
Auf dieser Seite kannst Du dir noch ein wenig mehr an Information herunterladen:
<a href="http://www.echostar.nl/b2c/support/support.asp?menulink=documents&mainlink=documents" target="_blank">http://www.echostar.nl/b2c/support/support.asp?menulink=documents&mainlink=documents</a>
Rokie
BeitragVerfasst: Do 2. Mai 2002, 14:09
Aslo ich kann mich meinem Vorgänger anschließen. Seit jetzt die offizielle 300 Software verfügbar ist, läuft die Box einfach genial.
Genial ist auch das EPG. Die Daten werden auf der HDD gespeichert. Wenn Du das EPG aufrufst kannnst Du immer sehen was auf allen Kanälen gerade läuft!
Ich habe nur einen Bug gefunden: Wenn Du mehrere Indexe für einen Film setzt und löscht davon einen wieder, springt er bei der Anwahl des nächsthöheren Index immer nooch zum vorhergehenden (gelöschten)...Also ich kann damit leben.
Und ein Manko ist noch, daß Du nicht einen Film aufnehmen und einen Anderen oder den gerade aufnehmenden ansehen kannst.
Letzters geht nur im Live-Pause Mode. Dann ist der Film allerdings nicht auf der Platte gespeichert.
Gruß,
SuperPower
<small>[ 02 Mai 2002, 16:12: Beitrag editiert von: superpower ]</small>
