Aktuelle Zeit: So 18. Mai 2025, 08:16
 Betreff des Beitrags: Neue Topfield TF-4000 PVR Firmware vom 28.Oktober
BeitragVerfasst: Mo 28. Okt 2002, 15:07
New firmware of TF4000PVR was released today.
It is a semi-official version.
We will release it at our homepage and OTA via Astra after beta-testing.
The hangup problem in the previous beta version shall be fixed, I hope.
It was because we changed the EPG scheme to speed it up.
1. IRD status of Oct 28 2002 version
(1) system id : 206
(2) loader version : A3.06
(3) device version : v4.3.60
(4) application version : TF-JPC 4.57.59
(5) last update : Oct 28 2002
2. Improvements of this version
(1) There shall be no problem in descrambling France2/3
in Astra 12515MHz with the Aston CAM.
(2) There was a problem while watching the subtitle with the software teletext.
The previous subtitle line was not erased. It is fixed.
(3) The problem of delayed recording with weekly mode is fixed.
(4) When the system records a service with the descrambled format,
the system will keep it as the decrambled format even menu,
EPG or some other operations except for channel change and time-shift mode.
(5) The overall performance is a little bit enhanced. You can try it
with the menu in teletext services.
(6) There was an index number in the date cell of recorded file list
when you saved the cut file. It is fixed.
(7) If a recorded file is locked, the image of instant view window will be also locked.
(8) The delayed recording menu is completely changed to VCR style.
(9) The running time of the cut & saved file was not so correct. It is improved.
(10) There is a change in EPG processing scheme. The EPG speed is
a little bit faster than the previous version.
(11) There was a problem of marking two events as the current simultaneously
in EPG. It is fixed.
Topfield Co., Ltd.
4th Floor, Deoksan bldg., 260-4, Seohyun-dong,
Bundang-ku, Seongnam, 463-824, South Korea
Beobachtungen über alle Topfield
Probleme werden von uns ggf, in
die englische Sprache übersetzt
und sofort nach Korea weitergeleitet:
http://www.bfm-satshop.de/
(Topfield Händler)
