http://satellite-board.de/board/
RF-Modulator - MC44355DW
http://satellite-board.de/board/viewtopic.php?f=45&t=20015
Seite 1 von 2
Autor:  oli [ Sa 13. Okt 2007, 20:47 ]
Betreff des Beitrags:  RF-Modulator - MC44355DW
http://dvb-community.de/wiki2/images/te ... Modul1.pdf
Autor:  oli [ So 14. Okt 2007, 17:31 ]
Betreff des Beitrags:  Re: RF-Modulator - MC44355DW
POWER_ON
Flash 0  : MX29LV320B (2M x 16)
Flash 1  : flash unknow
build: Oct 14 2007, 19:20:58
 RamSize 8384512 FirstAvailMem: 3031388
accept 1 002EB4D4
accept 2 002ECADC
***** IICDeath
***** IICDeath
[P_MAIN_Init]
# Module         Description                    Version  Modified            #
# EEPROMManager  EEPROM Manager                 1.8.2.1  2004/06/18 13:58:21 #
# RTCManager     Real Time Clock Manager        1.13.2.1 2004/06/16 16:14:15 #
# TManager       Timer Manager                  1.15     2004/02/18 10:55:35 #
# FEM            Frontend Manager               1.53.2.5 2004/10/11 11:39:27 #
# GPIO           GPIO                           ---      ---                 #
# FK             Front Keys                     1.7      2004/01/21 14:55:11 #
# PREMIERE       PREMIERE                       1.2      2004/01/14 08:49:16 #
# SSUDM          SSU08.01.2004 13:5908.01.2004 13:5908.01.2004 13:59 #
# Download Module 1.7.2.1  2004/07/28 11:23:18 #
********************************* BOX   INFO *********************************
* Module         Description               |     Driver SW     |     I2C     *
*                                          |Version |Modified  |W   |R   |B  *
***** IICDeath
* MESSAGING                                |        |          |0x00|0x00|000*
[PCF8574] Start Init... ***** IICDeath
* FLASH          MX29LV320B (2M x 16)      |1.23    |2004/04/08|0x00|0x00|000*
Resetting Port
* USB                                      |        |          |0x00|0x00|000*
* ENCODER        BT864                     |1.2     |2004/02/18|0x8a|0x8b|000*
***** IICDeath
***** IICDeath
***** IICDeath
***** IICDeath
***** IICDeath
* AVMUX          AK4702                    |1.3     |2003/11/28|0x22|0x22|000*
* MPEGCORE                                 |        |          |0x00|0x00|000*
* DEMUX                                    |1.29.2.1|2004/09/27|0x00|0x00|000*
Enabling Port
* AUDIO                                    |        |          |0x00|0x00|000*
* VIDEO                                    |        |          |0x00|0x00|000*
USB_AttachnewDevice Fullspeed:1
USB_SetAddress 03
Reading Device Descriptor
This endpoint supports a maxtransfersize of 08
Device Descriptor:
  UsbSpec 0110 * BOOTLOGO                                 |        |          |0x00|0x00|000*
Class 00 * IR_DRIVER                                |    VIDEO: Video Buffer empty
    |          |0x00|0x00|000*
SubClass 00 Prot 00 MaxPacket 08
  Vendor 0846 Product 1020 Release 0101
  ManuString 01 ProductString 02 SerialString 03
* OSD                                      |        |          |0x00|0x00|000*
  NumConfigs 01
Manufacturer: NETGEAR
Product: NETGEAR FA101 Adapter
Serial: 0001
Config 0:
Interfaces: 01 ConfigVal 01 StringInfo 00 Bus-powered  RemoteWakeup ***** IICDeath
160mA
***** IICDeath
  IF: Num 00 Alt 00 EPs 03 Class 00 SubClass 00 Prot 00 StringIdx 00
***** IICDeath
    EP: Addr 81 ***** IICDeath
Bulk    ***** IICDeath
MaxSize 0040 PollInterval 00
***** IICDeath
    EP: Addr 02 ***** IICDeath
Bulk    MaxSize 0040 PollInterval 00
    EP: Addr 83 Inter.  * STRUCTURE                                |        |          |0x00|0x00|000*
MaxSize 0008 PollInterval 01
* VCRTIMER                                 |        |          |0x00|0x00|000*
[Scan_Init]LinearScan Queue Create Failed
Interfaces: 01 ConfigVal 01 StringInfo 00 Bus-powered  RemoteWakeup * APPLICATION    BANNER                    |1.9.2.16|2004/11/04|0x00|0x00|000*
160mA
* APPLICATION    HELLO_WORLD               |1.3     |2004/05/18|0x00|0x00|000*
* APPLICATION    SETUP                     |0.3     |  13052003|0x00|0x00|000*
    EP: Addr 81 * APPLICATION    EPG                       |0.2     |  06052003|0x00|0x00|000*
Bulk    * APPLICATION    CA                        |0.1     |  14052004|0x00|0x00|000*
* APPLICATION    TEST                      |0.2     |  06052003|0x00|0x00|000*
    EP: Addr 02 * APPLICATION    VOLUME BAR                |0.1     |  28072003|0x00|0x00|000*
Bulk    * APPLICATION    JPEG                      |0.2     |  06052003|0x00|0x00|000*
* APPLICATION    TTX                       |0.2     |  06052003|0x00|0x00|000*
    EP: Addr 83 * APPLICATION    SOUND                     |0.2     |  06052003|0x00|0x00|000*
Inter.  * APPLICATION    SUBTITLE                  |0.2     |  06052003|0x00|0x00|000*
* APPLICATION    MSGWIN                    |1.6.2.20|2004/10/20|0x00|0x00|000*
USB ADM8511 compatible ethernet adapter detected
* APPLICATION    FRONT_KEY                 |0.1     |  04122003|0x00|0x00|000*
* APPLICATION    FIRST INSTALLATION        |0.1     |  28072003|0x00|0x00|000*
* APPLICATION    MULTI INFORMATION WINDOW  |1.30.2.7|2004/10/20|0x00|0x00|000*
* APPLICATION    ZOOM WINDOW               |1.6.2.1 |2004/07/30|0x00|0x00|000*
* APPLICATION    Tic Tac Toe WINDOW        |1.7.2.2 |2004/07/30|0x00|0x00|000*
* APPLICATION    MAIN APPLICATON           |1.1     |2004/06/08|0x00|0x00|000*
* APPLICATION                              |        |          |0x00|0x00|000*
* TELETEXT                                 |        |          |0x00|0x00|000*
* CLOCK                                    |        |          |0x00|0x00|000*
* SI_ENGINE      version notif dmx         |1.31.2.2|2004/06/21|0x00|0x00|000*
Invalid EEPROM for Conax Keystore
++++ Conax module initialization failed ! +++
[CW_CheckEMMStorage] EMM_Storage
*CW_Profile1: Model:     0x385*
*CW_Profile1: Release:   0x004*
*CW_Profile1: Version:   0x001*
*CW_Profile1: ImageId:   0x001*
*CW_Profile2: Model:     0x385*
*CW_Profile2: Release:   0x004*
*CW_Profile2: Version:   0x001*
*CW_Profile2: ImageId:   0x001*
 ADAM VERSION 1.09
* CA_SYSTEM      Embedded CAS Handler      |1.39.2.3|2004/08/20|0x00|0x00|000*
* Subtitle                                 |        |          |0x00|0x00|000*
* Fingerprinting                           |        |          |0x00|0x00|000*
* CONSOLE                                  |        |          |0x00|0x00|000*
USB_ADM8511_DeviceStart
Our IP: 192.168.1.99 !
Our MAC:00095B1BB618
MAC Reset ok
Readeepreg result: 23
MAC:0009B6185001
----- no card yet ---- -> start close timerGOAL_PrgfldProgName present
 SMRB Inside get_fpbutton FUNCTION
[setup]add_ca_entries()
[common_setup]get_entrie_ca()
tvformat.jpg [ 32.78 KiB | 22225-mal betrachtet ]
Autor:  oli [ Mo 15. Okt 2007, 06:06 ]
Das ist wirklich ein Wust. Was haben sich die bei GX nur gedach als sie das programmiert haben? War das eine Maßnahme zur Arbeitsplatzsicherung?
Man kann in der GOAL die Anzeige der RF Einstellung unter TVFormat anknipsen, aber die Treiber des Modulators laufen dann noch lange nicht. Die sind so verworren, da gibt es n APIs die alle nicht funktionieren. Auch die ganze i2c sachen da wurde das read / write tausend mal geändert und die funktionen ausgetauscht, manchen laufen noch mit etwas älteren Funktion dann wieder mit der neueren.... dann ist es n mal verschachtelt eine read ruft nur wieder eine andere read auf, Schwachsinn.
Ich glaube wenn wir an einer Stelle anfangen müssen wir alles neu schreiben, was ich mit dem RF Treibern jetzt machen werde.
Autor:  jimjack [ Mi 17. Okt 2007, 18:09 ]
Hmmm. Läuft der RF-Modulator?
Falls man das neu machen würde müsste man sich konzeptionell erst mal einiges überdenken.
Ganz von vorne wird wohl eher nicht werden, da sind, glaub ich, zu wenige dran beteiligt.
Aber auf jeden Fall gebe ich dir recht - es ist ein verworrener Wust...
Vielleicht reicht es auch erst einmal die Low-Level-Routinen neu zu machen (I2C, etc...)?
Autor:  oli [ Do 18. Okt 2007, 04:57 ]
Ich bin jetzt dazu übergegangen dem Balast mal zu löschen. Er ist ja nicht verloren irgendwo haben wir ihn ja noch. Aber diese ganzen RF Treiber haben alle nicht funktioniert und mein neuer Treiber hat nur drei Funktionen und hat nut 7k. Ich bin der Meinung das er sogar läuft, jedenfalls hatte ich schonmal ein scharzes Bild, ich hatte die Video/Audio-Leitungen noch nicht verbunden.
Was nicht geht ist das verstellen des RF Kanals im Menü.
Bei der ganzen Sache ist mir aber eine neue Grenze bewust geworden, das Netzteil. Also 3LNB über einen 4/1 Multischalter, dann das 4BankSAA Display, das USB/LAN und jetzt der RF sind wohl zuviel. Die Spannugen brechen zusammen und die Box geht in eine Bootschleife. Vielleicht sollten wir ein NT einer Easy oder Matrix verwenden, dann müssen wir auch keine Spannungen wie die 30V für den RF selber bauen.
Autor:  pepiz [ Sa 26. Jan 2008, 17:16 ]
Wurde der Modulator eigentlich auch für die Easy entwickelt oder ist ein einbau in die easy nicht möglich ?
Wenn ja , Kannst ihr mir ev. Unterlagen zukommen lassen ?
Danke
Autor:  oli [ So 27. Jan 2008, 15:56 ]
Diesen Tuner haben wir ja aus der alten Plattform "geklaut" was die Sourcen angeht, und die Schaltung zum Teil, zum Teil ist die Schaltung und auch die Treiber noch eine Baustelle. Im Moment kann ich nicht mal das Testbild einschalten da der Tuner nicht korrekt auf i2c antwortet.
Autor:  pepiz [ So 27. Jan 2008, 17:13 ]
Wie wäre es wenn man einen Einfacheren Modulator nimmt mit einer fixen Ausgangsfrequenz (z.B.HL-RMBT-e36H4; Ist in einigen VCR geräten von Philips und Grundig verbaut)?
Dann dürfte die Softwareanpassung bei weitem nicht so ein großes Problem sein !
Autor:  Hightech Master [ So 27. Jan 2008, 17:50 ]
aber das bezieht sich doch auf bestimmte Modulatoren !? Das müsste dann einer sein der schonmal in einem Gerät verbaut wurde von galaxis dessen Source wir haben!
Autor:  pepiz [ So 27. Jan 2008, 17:56 ]
Verstehe ein X beliebiger Modulator funktioniert also nicht
Autor:  Hightech Master [ So 27. Jan 2008, 19:20 ]
nee, sonst hätte wir uns schon bei dem kleinsten den es gibt bedient ;)
Autor:  oli [ So 27. Jan 2008, 20:29 ]
Sollte sicher gehen, nur ich wollte einen wo man den TV Kanal per i2c einstellen kann, nicht mit dem Schraubenzieher.
Autor:  jimjack [ Mo 28. Jan 2008, 08:55 ]
Wir müssen hier mal aufpassen!
Hier vermischen sich zwei Sachen in diesem Thread. Das eine ist der RF-Modulator udn das andere ist die adam-C-Variante (DVB-C-Tuner).
Einmal Ausgang und einmal Eingang.
Vielleicht kannst Du den Thread trennen oder wir machen für die DVB-C-Variante einen neuen Thread auf?
Edit: Danke Oli!
Autor:  oli [ Mi 30. Jan 2008, 07:13 ]
@pepiz, @M.U.T.E.B.
Gibt es grundsätzlich Interesse an dem Basteln am RF? Im Moment ist dies ja eine Baustelle siehe auch TV Format Menü.
Ich habe aber eine größere Zahl dieser Mods gekauft und könnte sie weiter geben.
Unterlagen zur Schaltung kann ich auch hier rein stellen!
Autor:  jimjack [ Mi 30. Jan 2008, 12:39 ]
Da ich keinen Modulator benötige wäre das eher akademischer Natur...
Seite 1 von 2 Alle Zeiten sind UTC
http://www.phpbb.com/
