^Hallo Freunde !
Habe versucht meine Easy Box mit der ital Software zu bespielen aber leider erfolglos, hier mein log Kann ir einer weiterhelfen ??
++++++ POWER OFF ++++++#INTPRT[RUNNING] exited, status:0xa
AV:lc_video_stop
#INTPRT[CLEANING_UP] init
++++++ POWER ON ++++++
Write Flash Error at 2c3b0000
FreeTV boot ver 2.50 Sep 25 2000 at 16:26:44
CPU: TMX320AV7111, Flash 2MB
Thank you for buying. galaxis development team
Bootloader update ver 1.00 Feb 07 2002 at 11:03:05
found 4 MB flash
check: found version 2.50 onboard
check: found version 2.50 attached
0
BUILD : Feb 03 2004 16:18:29
VERSION : 2.1.4
MANUFACTURER : GALAXIS
DOWNLOAD
Manufacturer_id : 46545601
Hardware_id : 2
Usage_id : 2
SW_version : 30
TID : 869f
BID : 1040
user_version : 06082002
channel_version : 13112001
(OTVSync_Tsl) 38 ts in tsl list
=================== HARDWARE LIST ===================
Flash driver version : 1.030 14/03/2002
SW update version : FREETV 1.018 20/05/2002
Demodulator version : 1.003 14/03/2002
Scan Version : 1.019 14/05/2002
Dram_Size : 2 MB
Dram2_Addr: 0
SDram_Size: 4 MB
Flash1 : AMD 29LV160BB id = 1, Device id = 2249
Flash2 : ---
Eeprom_Typ: ---
Disp_Typ : SAA 1064
AVmux_Typ : CXA 2161
Scart : two/three Scart
AC3_Typ : CS8405 present
RFmod_Typ : ---
FE_Typ : QPSK LG
Modem : ---
CIMax : present
Int. Test
#SECURE:WARNING: / is not permanent
gdbo raw port not initialized
#INTPRT[RESET] starting
#INTPRT[RESET] init
Cannot program connect to com_0.passive
#INTPRT[RUNNING] running:0x2
Bin wieder für ´jeden Hinweis dankbar !
Liebe Grüße aus Wien
Andreas
