Aktuelle Zeit: Mi 1. Jul 2026, 13:13
Ein neues Thema erstellen Auf das Thema antworten  [ 31 Beiträge ]  Gehe zu Seite 1, 2, 3  Nächste
 Betreff des Beitrags: BMP Format mit 7 Siegeln???
BeitragVerfasst: Do 3. Jan 2008, 21:14
Hier mal ein guter Link den mir M.U.T.E.B. gegeben hat:
http://www.fh-wedel.de/~bek/c/data/bmp.txt
Das ist mal nur ein Format Rätsel...
//// bitmap name = 3Decke_mirror
// bitmap size = 90
0x5a, 0x00, 0x00, 0x00,
// bitmap width = 9 (Bytes = 9)
0x09, 0x00,
// bitmap height = 9
0x09, 0x00,
// bitmap bitcount = 8
0x08,
// data
0x00,0xe1,0xe1,0xe1,0xe1,0xe1,0xe1,0xe1,0xe1,
0xd7,0x00,0xe1,0xe1,0xe1,0xe1,0xe1,0xe1,0xe1,
0xd7,0xd7,0x00,0xe1,0xe1,0xe1,0xe1,0xe1,0xe1,
0xd7,0xd7,0xd7,0x00,0xe1,0xe1,0xe1,0xe1,0xe1,
0xd7,0xd7,0xd7,0xd7,0x00,0xe1,0xe1,0xe1,0xe1,
0xd7,0xd7,0xd7,0xd7,0xd7,0x00,0xe1,0xe1,0xe1,
0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0x00,0xe1,0xe1,
0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0x00,0xe1,
0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0x00,
Ich habe die Bytes mal über den BBCode den Farbwert der zugehörigen Tabelle zugeordenet. Ob das der weißheit letzter schluß ist? Denke intern werden andere Farbwerte zugeordenet???
Hier noch die Rundeecke die ich im Moment verwende:
0x89, 0x00, 0x00, 0x00, // bitmap size = 137
0x08, 0x00, // bitmap width = 16 (Bytes = 8)
0x10, 0x00, // bitmap height = 16
0x04, // bitmap bitcount = 4
// data colortable
0x22,0x22,0x22,0x22,0x22,0x22,0x22,0x22,
0x62,0x22,0x22,0x22,0x22,0x22,0x22,0x22,
0x66,0x22,0x22,0x22,0x22,0x22,0x22,0x22,
0x66,0x62,0x22,0x22,0x22,0x22,0x22,0x22,
0x66,0x66,0x22,0x22,0x22,0x22,0x22,0x22,
0x66,0x66,0x62,0x22,0x22,0x22,0x22,0x22,
0x66,0x66,0x66,0x22,0x22,0x22,0x22,0x22,
0x66,0x66,0x66,0x66,0x22,0x22,0x22,0x22,
0x66,0x66,0x66,0x66,0x66,0x22,0x22,0x22,
0x66,0x66,0x66,0x66,0x66,0x66,0x22,0x22,
 Betreff des Beitrags: Re: BMP Format mit 7 Siegeln???
BeitragVerfasst: Do 3. Jan 2008, 22:50
dann müsste das :
0xa8,0xa8,0xa8,0xa8,0xa8,0xa8,0xa8,0xa8,0xa8,0xa8,0xa8,0xa8,0xa8,0xa8,0xa8,0xa8,0xa8,0xa8,0xa8,0xa8,0xa8,0xa8,0xa8,0xa8,0xa8,0xa8,0xa8,0xa8,0xa8,0xa8,
0xb4,0xb4,0xb4,0xb4,0xb4,0xb4,0xb4,0xb4,0xb4,0xb4,0xb4,0xb4,0xb4,0xb4,0xb4,0xb4,0xb4,0xb4,0xb4,0xb4,0xb4,0xb4,0xb4,0xb4,0xb4,0xb4,0xb4,0xb4,0xb4,0xb4,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
die deutsche flagge sein!
BeitragVerfasst: Do 3. Jan 2008, 23:11
Sie müßte aber auf dem Kopfstehen wie bei BMP üblich...
Aber siehe die Farben oben.... passen die hinterlegten Farben der Tabelle (SHAPEID_COLORTABLE) nicht zu den Farbwerten in den BMPs. Es sei den internwird nicht diese VGA Tabelle sondern eine Tabelle BMP eigen verwendet???
BeitragVerfasst: Fr 4. Jan 2008, 00:41
wenn was internes verwendet wird, wird das nen chaos!
BeitragVerfasst: Mo 4. Feb 2008, 12:16
ich habe bis jetzt nichts gefunden? Jemand schon nen Converter oder so? Weil es wäre vorteilhaft die Sachen mit Programmen zu machen und anschließend zu konvertieren!
BeitragVerfasst: Di 2. Dez 2008, 21:46
gibt es im moment lösungsvorschläge oder wird das nie was?
BeitragVerfasst: Di 2. Dez 2008, 22:17
Man könnte schon was schreiben, im moment mache ich das von hand...
BeitragVerfasst: Di 2. Dez 2008, 22:19
weil, ich habe überlegt, desto größer die sind, desto qualitativer die Bilder, stimmt das? Dann könnte man ein BMP-Menü machen, bzw. das aktuelle verschönern, optisch aufbessern
BeitragVerfasst: Di 2. Dez 2008, 22:32
Für den Background stimmt das, die OSD haben aber eine feste Auflösung. Könnte man aber auch erhöhen, noch nie probiert.
BeitragVerfasst: Mi 10. Dez 2008, 19:51
Ich habe mir die BMPs noch mal angeschaut, das sieht aufeinmal nicht so kompliziert aus. Ich habe alles mal zusammen gefaßt.
Hat jemand lust einen Konverter zu schreiben????
BMP_einbauen.pdf [10.92 KiB]
598-mal heruntergeladen
BeitragVerfasst: Fr 12. Dez 2008, 01:14
neue version
BMP_einbauen_r11.pdf [101.53 KiB]
590-mal heruntergeladen
BeitragVerfasst: Fr 12. Dez 2008, 21:54
Hier mal ein kleiner Konverter für kleine BMPs. Was ich gerde bräuchte wärem BMPs/C die 36x36 groß sind mit bittiefe 4. Die könnte ich dann zum Test gegen die Status BMPs austauschen.
bmp2c_R10.rar [8.59 KiB]
593-mal heruntergeladen
BeitragVerfasst: Sa 13. Dez 2008, 00:33
//82// shape - test
USHORT_2_UCHAR(SHAPEID_TEST_ICON), // shape id
USHORT_2_UCHAR(1), // number of draw function
SHAPE_BITMAP, // type of draw function
USHORT_2_UCHAR(0), USHORT_2_UCHAR(0), // distance x, y
//// bitmap name = Tango1
// bitmap size = 609
0x61, 0x02, 0x00, 0x00,
// bitmap width = 30
0x1e, 0x00,
// bitmap height = 20
0x14, 0x00,
0x08,
// data
0x36,0x36,0x12,0x36,0x12,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,
0x36,0x36,0x12,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,
0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36,
0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,
0xd7,
0xe9,0xd6,0xe9,0xe9,0xd6,0xd6,0xd6,0xd6,0xd6,0xd6,0xd6,0xd6,0xd6,0xd6,0xe9,0xe9,0xe9,0xe9,0xe9,0xe9,0xe9,0xe9,0xe9,0xe9,0xd6,0xd6,0xd6,0xd6,0xd6,
0xba,0xba,0xba,0xba,0xbb,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,
0xba,0xba,0xb4,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,
0xba,0xba,0xb4,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xb4,
0xba,0xbb,0xb5,0xb4,0xb4,0xb4,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xb4,0xb4,0xb4,0xb4,0xb4,
0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xb4,0xb4,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xba,0xb4,0xb4,0xb4,0xba,0xbb,
0xba,0x97,0x97,0x97,0x97,0x97,0x97,0x97,0x97,0x97,0x97,0x97,0x97,0x97,0x97,0x97,0x97,0x97,0x97,0x97,0x97,0x97,0x97,0x97,0x97,0x97,0x97,0x97,0x97,0x97,
BeitragVerfasst: Sa 13. Dez 2008, 00:54
0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,
0x07,0xd7,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,
0x07,0xd7,0xd7,0x07,0x07,0x07,0x07,0x07,0x07,0x07,
0x07,0xd7,0xd7,0xd7,0x07,0x07,0x07,0x07,0x07,0x07,
0x07,0xd7,0xd7,0xd7,0xd7,0x07,0x07,0x07,0x07,0x07,
0x07,0xd7,0xd7,0xd7,0xd7,0xd7,0x07,0x07,0x07,0x07,
0x07,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0x07,0x07,0x07,
0x07,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0x07,0x07,
0x07,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0x07,
0xbd,0x00,0x00,0x00,0x12,0x00,0x0a,0x00,0x08,
0x05,0x05,0x05,0x05,0x05,0x05,0x05,0x05,0x05,0x05,0x05,0x05,0x05,0x05,0x05,0x05,0x05,0x05,
0x05,0x05,0x56,0x56,0x56,0x56,0x56,0x56,0x56,0x56,0x56,0x56,0x56,0x56,0x56,0x56,0x56,0x05,
0x05,0x05,0x56,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0x56,0x05,0x05,
0x05,0x05,0x05,0x56,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0x56,0x05,0x05,0x05,
0x05,0x05,0x05,0x05,0x56,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0x56,0x05,0x05,0x05,0x05,
0x05,0x05,0x05,0x05,0x05,0x56,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0x56,0x05,0x05,0x05,0x05,0x05,
0x05,0x05,0x05,0x05,0x05,0x05,0x56,0xd7,0xd7,0xd7,0xd7,0x56,0x05,0x05,0x05,0x05,0x05,0x05,
0x05,0x05,0x05,0x05,0x05,0x05,0x05,0x05,0xd7,0xd7,0x05,0x05,0x05,0x05,0x05,0x05,0x05,0x05,
0xdc,0x0b,0x01,0x00,0x0c,
0x02,0x00,0x02,0x00,0xbd,0x00,0x00,0x00,0x12,0x00,0x0a,0x00,0x08,0x05,0x05,0x05,
0x05,0x05,0x05,0x05,0x05,0x05,0x05,0x05,0x05,0xd7,0xd7,0x05,0x05,0x05,0x05,0x05,
0x05,0x05,0x05,0x05,0x05,0x05,0x05,0x05,0x05,0x56,0xd7,0xd7,0xd7,0xd7,0x56,0x05,
0x05,0x05,0x05,0x05,0x05,0x05,0x05,0x05,0x05,0x05,0x56,0xd7,0xd7,0xd7,0xd7,0xd7,
0xd7,0x56,0x05,0x05,0x05,0x05,0x05,0x05,0x05,0x05,0x05,0x56,0xd7,0xd7,0xd7,0xd7,
0xd7,0xd7,0xd7,0xd7,0x56,0x05,0x05,0x05,0x05,0x05,0x05,0x05,0x56,0xd7,0xd7,0xd7,
0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0x56,0x05,0x05,0x05,0x05,0x05,0x56,0xd7,0xd7,
0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0x56,0x05,0x05,0x05,0x56,0x56,
0x56,0x56,0x56,0x56,0x56,0x56,0x56,0x56,0x56,0x56,0x56,0x56,0x56,0x05,0x05,0x05,
0x05,0xdd,0x0b,0x01,0x00,0x0c,0x0a,0x00,0x02,0x00,0xd1,0x00,0x00,0x00,0x14,0x00,
0x0a,0x00,0x08,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,
0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,
0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0x07,0x07,0x07,0x07,0x07,0x07,0xd7,0xd7,
0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0x07,0x07,0x07,0x07,0x07,
0x07,0x07,0x07,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0x07,0x07,
0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,0xd7,
0xd7,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0xd7,0xd7,0xd7,
0xd7,0xd7,0xd7,0xd7,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,
0x07,0x07,0xd7,0xd7,0xd7,0xd7,0xd7,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,
0x07,0x07,0x07,0x07,0x07,0x07,0x07,0xd7,0xd7,0xd7,0x07,0x07,0x07,0x07,0x07,0x07,
0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0xd7,0x07,0x07,0x07,
0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,
0x07
BeitragVerfasst: Sa 13. Dez 2008, 22:36
hier die BMP in RGB farben
