Aktuelle Zeit: Do 15. Okt 2026, 18:48
 Betreff des Beitrags: Problem with Galaxis receiver NOSF
BeitragVerfasst: Mi 3. Sep 2008, 17:22
Hello all,
Recently my galaxis IQg matrix broke. At first it stopped working properly, now it doesn't work anymore at all.
If I boot the device somethimes I get the "NoSF" error msg on the screen and sometimes I only see " - ".
I already tried to connect the receiver to the pc using a rs232 and null modem cable but this doesn't work. I don't see anything in hyperterminal.
I also opened the box but I can't see any visual damage.
If anybody has a clue please help out. All answers are welcome in German or English. My German reading skill are more the enough, writing is a bit more time consuming.
Greetings,
Bram
 Betreff des Beitrags: Re: Problem with Galaxis receiver NOSF
BeitragVerfasst: Mi 3. Sep 2008, 18:15
hallo ist dein Kabel wirklich ein Nullmodem Kabel mit Gender-Changer oder nur ein
COM-Anschlußkabel
DAS KABEL MUß AUF PIN 2 + 3 GEKREUZT SEIN
Ev. würde ich PL2.7 testen !
BeitragVerfasst: Mi 3. Sep 2008, 21:25
Hello,
You're right, I was simply using a bad cable. It's because this cable needs to be male-female and those cables are straight.
So I figured to get on the box via hyperterminal now. If I connect I get this:
FreeTV boot ver 1.10 May 22 2000 at 12:59:09
DRAM : 4MB, SDRAM : 4MB
Waiting for download using 1K-xmodem.
If I try to send a boot file via 1K Xmodem he says something like "maximum error's reached".
I also tryed PL2.7 but I still can't connect to the device with that software.
So what should be my next step?
Greetz,
Bram
BeitragVerfasst: Fr 5. Sep 2008, 16:13
Hello all,
I still didn't manage to get my problem solved. I was trying to upload a new bootloader bootsr310.bin but it seems that this didn't really work as it should.
Now when I boot the device, on the device itself I only see "----" via hyperterminal or PL2.7 I get the following error msg:
ERROR: SendI2cMsg(busy)!! at 70
serial Display
Could anybody help me out?
Cheers,
Bram
BeitragVerfasst: Di 25. Nov 2008, 17:19
After a few months I'm trying to pick this up again.
Nowbody has any idea how to solve this? The facts aren't changed.
Cheers,
Bram
BeitragVerfasst: Di 25. Nov 2008, 21:11
brambo hat geschrieben:
serial Display
Deine Flash Speicher sind defekt. Du mußt die Flash austauschen und dann den Bootloder über Jtag flashen.
BeitragVerfasst: Di 2. Dez 2008, 20:07
Hi Oli,
Thanks for your support!
Could you also advise me an howto to replace the flash? And what flash to buy?
Cheers,
Bram
BeitragVerfasst: Fr 12. Dez 2008, 19:27
The Flash is SMD soldered.
The Flash is not simple to buy. They are expensive. see:
http://de.rs-online.com/web/search/sear ... 2508750258
If you want I have still some Flash here? I recommend a soldering station with hot air.
http://iqzone.de/iqzone/jtag/jtag.html
