Aktuelle Zeit: Di 24. Dez 2024, 00:04
 Betreff des Beitrags: Video Win & PVR (beides neuste Versionen) Probleme
BeitragVerfasst: Di 1. Jan 2002, 11:02
VideoRip bleibt einfach stehen:
c:\#filme>pvrripper
Usage:
pvrripper dir drivename
to get a directory listing
example:
pvrripper dir g:
OR
pvrripper rip drivename recordno length_in_seconds
to rip a file
example:
pvrripper rip g: 1 600
rips record number 1 from drive g: with a length of 600 seconds
PVRRipper v0.5.7
enjoy using it
(c)2001 by Boom
c:\#filme>pvrripper rip d: 4 3589
TOC shows
Files= 17
Used clusters= 489
Free clusters= 83
RecordNo =4
Station =ZDF
Clip =Andrea Bocelli in der Toskana
Date =9.12.2001 16:4:11
Length =0:59:49
Length in s =3589
SkipIndex =
VClusters =17 means max 1700 MByte
AClusters =1 means max 100 MByte
VClusters = 9f a1 a2 a3 a4 a5 a6 a7 a8 a9 aa ab ac ad ae af b0
AClusters = a0
analizing streams...
Dump clusters... 9f a1 a2 a3 a4 a5 a6 a7 a8 a9 aa ab ac ad ae af b0
Dump clusters... a0
Videostream=e0
Audiostream=c0
try to find first pts for Audio...
Audiostream PTS=5082926708
try to find first pts for Video...
Videostream PTS=5082991500
First PTS=5082991500
Max PTS=5405936708
now ripping audio
CPVRFile::RipAudioStream
Try to rewind... passed!
found PTS 5082991508 running...
patience... running...
... it took 17 seconds...
now ripping video
CPVRFile::RipVideoStream
rewinding stream...okay
seeking stream start code 1e0
now ripping until eobs...
at PTS=5140771500
... hier bleibt das Proggy stehen !!!
LOG:
PVRRIPPER LOG v0.5.7
CPVRDrive::CPVRDrive
reading file 0
CPVRFile::CPVRFile(char *Drivename, int FileNo)
reading file 1
reading file 2
reading file 3
reading file 4
reading file 5
reading file 6
reading file 7
reading file 8
reading file 9
reading file 10
reading file 11
reading file 12
reading file 13
reading file 14
reading file 15
reading file 16
RecordNo =4
Station =ZDF
Length =0:59:49
Length in s =3589
SkipIndex =
AClusters = a0
GetStreamIDs
try to rewind... okay
Dump clusters... a0
GetStreamIDs
Videostream=e0
Audiostream=c0
FirstPTS AUDIO 1c0
try to rewind...okay
found PTS 5082926708
audio pts... means doodeldee... gotit!!! -> return
FirstPTS VIDEO 1e0
found PTS 5082980700
waiting... for 0x000001B3
found PTS 5082991500
got 0x000001B3 after PTS 5082991500... return
Max PTS=5405936708
COBits::COBits
004 - Andrea Bocelli in der Toskana.mp2
filehandle okay
1c00908 is not the expected startcode!
PES ist not okay OR PTS is less then StartPTS
100 is not the expected startcode!
COBits::COBits
004 - Andrea Bocelli in der Toskana.m2v
filehandle okay
reached pts 5082991500
shit.. i'm video and i have to wait until 0x000001B3....
yeah.. i'm video and i reached 0x000001B3....
goto next cluster 1/161
goto next cluster 2/162
goto next cluster 3/163
M2V-File wird weitergeschrieben, allerdings steht nur sowas:
à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à à
Drin. Hat jemand eine Idee?
Aufnahme auf dem H 820 wurde nicht angefasst bzw. geteilt!
[ 01. Januar 2002: Beitrag editiert von: sat_user ]
BeitragVerfasst: Di 1. Jan 2002, 11:20
Aufnahme geteilt ?
Warscheinlich nicht Ok, Auufnahme auch Ok (Siehe ältere Beiträge von mir) und Satschüssel richtig ausgerichtet.
Dann war hier schon öfter gesagt worden das man niemals das ganze File rippen soll
(Hatte damit allerdings auch nie Probleme, aber wär ein versuch Wert).
Oder evtl. mal mit einer alten PVRripper Version versuchen, glaube 0.29a.
Die rippt auch defekt Files.
Tinkie
BeitragVerfasst: Di 1. Jan 2002, 12:13
Hallo Tinki, Nein nicht geteilt.
Die PVR 0.47a scheint "drüberweg" zu laufen.
Ist allerdings sehr langsam.
+ Allerdings lässt sich dann OUT.XXX nicht mehr muxen. TMPGenc frisst nur noch virtuellen RAM.
Hmm.. gibt es einen toleranteren Muxer?
Die Aufnahme läßt sich im Hunny 820 "völlig normal" abspielen. Sieht ok aus. Komisch....
Danke für Deine Antwort...
