Aktuelle Zeit: Mo 23. Dez 2024, 18:37
 Betreff des Beitrags: irdeto 900440 microsystem problem(English)
BeitragVerfasst: Di 23. Jan 2001, 23:38
hello
thanks for your answer. i have an irdeto microsystem 900440.i made from this camfree2 before ,but i had tried to make allcam 4.06 for watching x-net by loading IRD47.sbr but when i run ird106.exe with IRD47.sbr the program window will become "red" and
at the end my the reciver and the laptup don't know my ci medule.i try for repair by cooling but i can't do it.
please help me for repaireing my ci medule.
i'm looking forward you.
thank you so much
BeitragVerfasst: Mi 24. Jan 2001, 08:37
I'm not quite sure what kind of device you have. I'm not familiar with the description "irdeto microsystem 900440". But assuming this is standard Irdeto CI module and you would like to convert it to a ALLCAM (Irdeto + Betacrypt) module with software revision 4.6SE or 4.7SE you have to use the xxx.bin file to patch it with ird106.exe.
The xxx.sbr file is intended to be used for the Mediamaster 9800S only (serial mode). So if you already used the patch with the xxx.sbr file I'm afraid that you destroyed the contents of the EEPROM within your module. This can only be repaired by exchanging this chip. Bad luck Bild
BeitragVerfasst: Mi 24. Jan 2001, 19:12
Space_2063, i believe the second part of your answer is not completely correct. SBR-Files r for the SCSI-Transfer with Nokia MM 9600 and vgrabber. If the content of the 29F002 is not completely overwritten he has a good chance to reactivate his CI.
BeitragVerfasst: Mi 24. Jan 2001, 22:14
@StinkePilz
thanks for the info. I read the MM900 information somewhere in a board and thought is was correct Bild (I'm always using a laptop to patch a module)
