Aktuelle Zeit: Fr 31. Jul 2026, 20:04
 Betreff des Beitrags: Neue Soft für Topfield TF4000 PVR !!
BeitragVerfasst: Fr 12. Okt 2001, 10:06
Habe gerade eine e-mail von Topfield bekommen mit einem Softwareupdate .
Werde sie gleich mal ausprobieren und über Neuigkeiten berichten.
Dear Sir,
Please find the attached new software of TF4000PVR, released on Oct 11.
After the installation of this software, kindly let us have your results by return.
The details of this new software is as follows;
Improvements in this version
(1) The A/V sync. problem at playback is almost fixed.
(2) If the system does not access the HDD more than 3 minutes, the HDD will go to
standby mode automatically.
If the time shifting mode is disabled, the system does not access HDD for normal operation.
The playback or viewing the recorded list at HDD standby state will make the HDD reoperation.
(3) The system saves the last channel of each tuner.
(4) When recoding TV service, you can go to Radio service even if the TP of the last radio
service is different from the TV service.
(5) The system shows the current sleep time at first pressure of sleep key.
(6) The stability of HDD function is very improved.
(7) The speed of EPG is a little enhanced.
(8) The time shifting problem at signal unlocking is fixed.
(9) You can got to the other tuner's channels while recording by just P+/P- key, not to mention
pressing channel number.
(10) System halt problem is fixed when the signal strength is some low state. It was very rare even in
the previous version.
(11) The system does not show the info box in the unnecessary state.
(12) Some trival bugs are fixed.
3. Next version will be available in th 26th Oct. Most of the following functions will be added.
(1) Much improving the speed of EPG.
(2) Deutch, Danish, Swedish and Norwegian translation of menu strings.
(3) Skip 30 seconds at playback or time shifing.
(4) etc...
digisat
[ 12. Oktober 2001: Beitrag editiert von: digisat ]
BeitragVerfasst: Fr 12. Okt 2001, 11:00
würdest du mir bitte das file mailen.
THX
BeitragVerfasst: Fr 12. Okt 2001, 12:12
Schau mal hier:
http://board.satshop.com/board/Forum21/HTML/000007.html
BeitragVerfasst: Fr 12. Okt 2001, 20:47
Hallo, hab sie auch heute bekommen und gleich installiert.
Allerdings habe ich an und ab leichte Ruckler bei der Wiedergabe feststellen können, was mir in der letzten Soft nicht aufgefallen ist.
Das Wiedergeben von Radioaufnahmen klappt bei mir gar nicht. Ein paar zusammenhangslose Töne und die Meldung "sendet nicht oder verschlüsselt" (wohlgemerkt bei der Wiedergabe).
Läuft die Software bei Euch glatt?
Huor
BeitragVerfasst: Sa 13. Okt 2001, 07:29
Habe gestern Abend die neues Soft getestet und zumindest bei mir ist das Sync Problem beim time shifting fast nicht mehr vorhanden. Der epg ist nicht merkbar schneller geworden, aber das soll ja auch erst am 26. Oktober kommen.
@Huor
Dieses Problem trat bei mir in der letzten Zeit auch manchmal auf und zwar nicht nur bei Radio sondern auch bei TV. Obwohl Bild und Ton während der Aufnahme am Fernseher richtig wiedergegeben wurden, war die Aufnahme trotzdem schrott (Bild ruckt, Ton ist verzerrt).
Ich habe dann das Gerät auf Werkseinstellung zurückgesetzt, auf jedem Tuner einen kompletten Suchlauf für Astra und Hotbird gemacht und seitdem funktioniert es problemlos, auch die Aufnahme von Radioprogrammen. Ich nehme mal an, daß entweder der Setting Editor Probleme macht, oder daß ich vielleicht beim ersten Einrichten des Geräts (LNB Einstellungen) einen Fehler gemacht habe und durch den Setting Editor diese falschen LNB Einstellungen immer wieder in das Gerät eingespielt habe.
cu
Stefan
BeitragVerfasst: Di 23. Okt 2001, 16:46
Ich weiß nicht, hat noch niemand diesen Bug (schon seit der letzen Beta drin) festgestellt ?? :confused:
