Aktuelle Zeit: Sa 4. Jul 2026, 20:17
 Betreff des Beitrags: GALAXIS IQG MATRIX.PLEASE HELP SOMEONE!!!!
BeitragVerfasst: Mo 26. Dez 2005, 15:00
hello everyone. i hardly found this forum that talks about GALAXIS digital receivers, sorry im talking in english but i dnt speak german, so i hope there will be someone willing to help me.
Ive got a digital receiver Galaxis IQg Matrix. the receiver dsnt work. when i turn it on it boots then says CH.38 and stucks, doesnt respond. i tried reprogramming it via PC but its dsnt work. now i want to unsolder the flash memories from the board and program them on my eprom programmer. the receiver has 2 Atmel flash. one AT49LV1614 and AT49BV1614. is it the bootloader in one flash and software in another? what i must program in each flash? im asking that because on AT49BV1614 it says boot002.bin.please help if someone knows what i must do. thank u
BeitragVerfasst: Mo 26. Dez 2005, 15:34
hi bumbadub & welcome
please could you attached the login of your box ?
regards
pooh
BeitragVerfasst: Mo 26. Dez 2005, 15:36
Hallo
man muss nur in den Boot Flash den Bootloader an 0x2c000000 programmieren. Dein Problem hat aber nichts damit zutun. Das ist ein typisches Problem. Die Atmel Flash Speicher gehen kaputt. Tausche beide Flash gegen AMD 29LV160. Dann programmiere (mit Jtag) den Bootloader an 0x2c000000 (ohne Header) des Boot Flash. Dann die Software seriell programmieren. Bist du in Deutschland?
Hello
one must program only into the boot Flash the Bootloader at 0x2c000000. Your problem has however nothing thereby to add. That is a typical problem. The Atmel Flash memory gets broken. Exchange both Flash for AMD 29LV160. Then program the Bootloader at 0x2c000000 (non header) boot of the Flash. Then the software serially program. You are in Germany?
BeitragVerfasst: Di 27. Dez 2005, 09:40
hello guys. on the back of the receiver there is a sticker. it says IQg.matrix 1901411193000544. how do i know which model of Matrix is this receiver, Matrix S, Matrix S AC3, Matrix C, Matrix Action S or Matrix CAS 1S? there is only 2CI in the receiver, nothing embedded. is it Matrix S? now, which bootloader i must download and which software is suitable for it? and please explain to me what do u mean when u say : program the Bootloader at 0x2c000000 (non header) boot of the Flash??? im using Willem eprom programmer, i usually load the .bin file and program the flash. how do i program the Bootloader at 0x2c000000 (non header) boot of the Flash? sorry for so many questions guys but i guess its no shame when u dont know something. im looking forward to hearing from u. many thanx
BeitragVerfasst: Di 27. Dez 2005, 11:07
You have a "Matrix S".
code of bootloader zap3.10 (*.bin file):
0x0000   1234 0000 ABD8 2C00 0000 06CA 0000 0000   .4....,.........
0x0010   EA00 0014 E59F F1AC E59F F1AC E59F F1AC   ................
The first 16 byte is the header. The header is only for the serial download of the *.bin file! Remove the first 16 byte from the *.bin file. The file begins then with 0x EA 00 00 14....
The Flash is broken (Atmel). Take new AMD Flash. Program this new file at 0x00 of the boot Flash. The place of old Atmel (boot002.bin). Solder the new Flash into the Matrix.
Then the Matrix already boot. Then bring serially the firmware in (v30.07.1.bin)
If did not function to something.... One does not have to program the Flash externally! One can use the existing Jtag port!
If one the Jtag used... the addresses of the Flash begins with "2c". The storage area is over the CPU from 0x2c000000 to 0x2c3FFFFFE. The Bootloader comes at 0x2c000000.
If still questions are.... simply still once ask! Apology for my English. One does not understand searches well over a foreign language. Which is your native language?
BeitragVerfasst: Di 27. Dez 2005, 15:29
Hi Oli. thanx for your invaluable help, i really appreciate it. ok, i downloaded the files. now how do i remove the first 16 bytes? i use Willem Eprom programmer software, do i just put FF FF FF FF in these bytes or i use another software to remove them?
BeitragVerfasst: Di 27. Dez 2005, 15:30
Hi Oli. thanx for your invaluable help, i really appreciate it. ok, i downloaded the files. now how do i remove the first 16 bytes? i use Willem Eprom programmer software, do i just put FF FF FF FF in these bytes or i use another software to remove them?i live and work in Greece
BeitragVerfasst: Di 27. Dez 2005, 16:54
Do not fill up with 0xFF. One must remove the headers completely.
before
after
0x0000   EA00 0014 E59F F1AC E59F F1AC E59F F1AC   ................
0x0010   E59F F1AC E59F F1AC E59F F1AC E59F F1AC   ................
BeitragVerfasst: Di 27. Dez 2005, 17:35
Oli I found a HEX editor and modified the 3.10 bootloader like u said the new file starts EA00 0014 E59F F1AC E59F F1AC E59F F1AC . i programmed the flash but when i soldered it to the board the receiver did not say boot on the front display, it doesnt boot. normally would it boot even without the second flash? do i have to remove the header from the software v30.07.1.bin too? or program it just like it is? help Oli
BeitragVerfasst: Di 27. Dez 2005, 19:25
On the display now "noSF" is located and in the log of the hyperterminal should the box should into the Download mode go (automatically). Then the Firmare serially send.
