Ich habe eine Galaxis Easy World geschenkt bekommen, die keine Sender mehr empfängt. Da scheint der Beta Chip defekt zu sein !?!?!
Nun versuche ich, ein Sftware Update. Verbindung zum PC ist da, aber beim einlesen stoppt er dann mit "no Signal".
hier mal das Protokoll:
SAA1064 Display
2MB Hardware .. idx= 0
CPU: TMX320AV7111, Flash 2MB
galaxis zapping team
Jump only first(0) Ver 5 check 9c10 addr 2c100000 !
SAA1064 Display
Timer: check time incorrect = 0x4383c3
ë Sep 20 2001 at 15:56:33
** SendI2cMsg err! at 86 cnt=1 ***
** SendI2cMsg err! at 38 cnt=2 ***
Timer: check time incorrect = 0x480001
---- End of system check ----
SVC St Base: 0x2e00334c Size: 0x800
IRQ St Base: 0x2e003b4c Size: 0x4000
UDF St Base: 0x2e007b4c Size: 0x800
ABO St Base: 0x2e00834c Size: 0x800
Priv Base: 0x2e01d840 Size: 0x80
Heap Base: 0x2e01d8c0 Size: 0x1d253f
Stack Base: 0x2e1efe00 Size: 0x10000
Flash: 0 - AMD 29LV160B , 5 waits
EEPROM: 24C16 (2Kx8)
Display: SAA1064 Display
Frontend: SAT Alps BSRU6
AudioV Mux: CXA2161 2 scart
Dolby AC3: Dolby AC3 CS8405a
RF Modul: ---
Modem: ---
Common IF: CIMaX 2 Slot
=== DEVICE on ====
FeTune: tp=28, frq=1248000, sr=275000, pol/t=1, sat=8, QAM=0, port 0 !
Tuner step: 1, freq: 1248300
Tuner step: 2, freq: 1247700
Tuner step: 3, freq: 1248600
Tuner step: 4, freq: 1247400
Tuner step: 7, freq: 1248000
=====> no signal <=====
SAA1064 Display
2MB Hardware .
SAA1064 Display
galaxis zapping
Timer: check time incorrect = 0x43c3c3
** SendI2cMsg err! at ca cnt=3 ***
RF Modul: ---
Modem: ---
=== DEVICE on ====
wwwwwwwwwwwwwwÿþwwwwwwwwwwwþwwww
SAA1064 Display
SAA1064 Display
RF Modul: ---
Modem: ---
=== DEVICE on ====
wwww
SAA1064 Display
SAA1064 Display
RF Modul: ---
Modem: ---
=== DEVICE off ====
SAA1064 Display
SAA1064 Display
Timer: check date incorrect = 0x0
RF Modul: ---
Modem: ---
=== DEVICE on ====
FeTune: tp=29, frq=1255200, sr=220000, pol/t=1, sat=8, QAM=0, port 0 !
Tuner step: 1, freq: 1255500
Tuner step: 2, freq: 1254900
Tuner step: 3, freq: 1255800
Tuner step: 4, freq: 1254600
Tuner step: 7, freq: 1255200
wþwwwww
SAA1064 Display
SAA1064 Display
RF Modul: ---
Modem: ---
=== DEVICE on ====
wwww
SAA1064 Display
SAA1064 Display
RF Modul: ---
Modem: ---
=== DEVICE on ====
ú
SAA1064 Display
SAA1064 Display
ERROR: modem ATE0 not accepted: 8000
ERROR: modem ATSE2 not accepted: 0
ERROR: modem ATSE3 not accepted: 0
ERROR: modem ATSE4 not accepted: 0
ERROR: modem ATSF4 not accepted: 0
ERROR: modem ATS07 not accepted: 0
ERROR: modem ATS14 not accepted: 0
ERROR: modem ATSF5 not accepted: 0
ERROR: modem ATSF6 not accepted: 0
ERROR: modem ATSF7 not accepted - 0
RF Modul: ---
Modem: PSTN Si2400 V.22bis
=== DEVICE on ====
Kann da einer was mit anfangen, bzw. kann ich mit der Box noch was machen?
Danke für eure Hilfe!!!!
Heinz-Werner
