Aktuelle Zeit: So 18. Mai 2025, 14:01
 Betreff des Beitrags: Neue Topfield TF-4000 PVR Beta-Firmware vom 23.Oktober
BeitragVerfasst: Mi 23. Okt 2002, 13:36
Folgende E-mail gerade erhalten:
Dear Sirs,
The beta software of TF4000PVR shall be attached.
Please refer to the following comments.
Best regards,
Jongwon Kim
0. This is the quick bug-fixing version for France2/3 in Canal+.
We got a report that there is a problem in descrambing those services with the Aston CAM.
1. IRD status of Oct 23 2002 version
(1) system id : 206
(2) loader version : A3.06
(3) device version : v4.3.60
(4) application version : BETA-JPC 4.57.00
(5) last update : Oct 23 2002
2. Improvements of this version
(1) There shall be no problem in descrambling France2/3 in Canal+ with the Aston CAM.
(2) There was a problem while watching the subtitle with the software teletext.
The previous subtitle line was not erased. It is fixed.
(3) The problem of delayed recording with weekly mode is fixed.
(4) When the system records a service with the descrambled format, the system will keep it
as the descrambled format even menu, EPG or some other operations except for
channel change and time-shift mode.
(5) The overall performance is a little bit enhanced. You can try it with the menu in teletext services.
(6) There was an index number in the date cell of recorded file list when you saved the cut file.
It is fixed.
(7) If a recorded file is locked, the image of instant view window will be also locked.
(8) The delayed recording menu is completely changed to VCR style.
Info
http://www.bfm-satshop.de/
