Aktuelle Zeit: So 6. Apr 2025, 09:47
 Betreff des Beitrags: Greets and problems
BeitragVerfasst: Mo 30. Apr 2001, 21:31
Sorry for posting in english. I can only read German for now. I have a new mcZap S with 0.4 software. And the search function does not work ok, the timer is stupid, everything looks weird software. From 100 chanels on Eutelsat I found only 12 altough the antenna was previously set up ok on Eutesat Hot Bird 13 with another receiver, which was the same type. I would need a little bit of advice and help , please ...
BeitragVerfasst: Mo 30. Apr 2001, 22:18
Das ist eine alte Software. Gehe mal auf „Software Update“ dann wird automatisch über Astra 19,2° die Software upgedatet. Wenn auf Hotbird nicht alle Programme gefunden werden kannst du ein fertiges Setting einspielen. Wobei mir die nur 12 Programme auf Hotbird nach einem analogen LNB klingen?
V32.01.4
[Dieser Beitrag wurde von oli am 01. Mai 2001 um 02:35 Uhr editiert.]
BeitragVerfasst: Di 1. Mai 2001, 04:22
I am sure I have a digital one. I had before a MacZap which worked perfect,...but after 1 day o waiting. In the first day I was searching for channels = nothing. The next day I did the same = everything. Without changing any setting at antena or receiver.
I will try to update the software with nullmodem kabel. I dont move my antenna anymore ...Bild, Thanks
BeitragVerfasst: Di 1. Mai 2001, 13:35
Thanks, Olli , solved. Your homepage was a lot of help for me.
